No power with key on
Old Jun 6, 2005 | 07:03 PM
fearthedeere's Avatar
Unhappy No power with key on
My lights work the dome light works the horn works, but nothing the key turns on works. i replaced my starter contacts and now there is no power to the key. The Truck is an electrical mess. Help, please.
Old Jun 6, 2005 | 09:31 PM
Scubasteve's Avatar
so everything worked and after you replaced the starter contacts most things don't work?
Better check all your fuses to make sure you didn't pop a few then go from there
Jason
Old Jun 6, 2005 | 09:34 PM
mr T's Avatar
did u reconnect both wires back to the starter? the main one and the tiny one?...did u reconnect all the wires to the battery terminal on the drivers side? maybe u just forgot one and its danglin and hard to notice...and ofcourse do check the fuses and relays
Old Jun 7, 2005 | 09:51 AM
spunbearing's Avatar
I still think that you have a fusible link burned out. I'm willing to bet that you have no power to your ignition switch.I'm gonna ask a stupid question. Did you disconnect the battery when you pulled the starter? If you didn't one little arc could have burned a fusible link. I think that main fusible link on mine is green. Test for power after the link. Usually you can see them burned.
Old Jun 7, 2005 | 09:59 AM
darkvader's Avatar
also chenk grounds frame and fire wall. see my reply on your more problems post 1st gen
Clark
jmccart
13
Oct 1, 2008 09:39 PM
stix
Aug 23, 2007 09:39 PM
rkelley
Oct 20, 2006 05:55 AM
big red psd cc
Dec 29, 2004 11:38 PM
