No power/Engine light
Old Aug 25, 2007 | 11:25 AM
scor572's Avatar
Angry No power/Engine light
New guy, need some advice.
I just took my '01 2500 5spd truck to the dealer because of an engine light, and severe lack of power. They said lift pump, injection pump, and MAP sensor all need to be replaced to the tune of 3800.00. What gets me is that the truck was running great, but one morning, the light came on, and it has no power. Starts fine, idles fine, but accelerates like a dog.
Injection pump was replaced 60K ago by dealer, lift pump 30k ago by me. Can they go that quick, or is it possible that a MAP sensor will cure it?
Also , I am unfamiliar with getting the codes out of these trucks.
Any help is appreciated.
Old Aug 25, 2007 | 11:32 AM
donhov's Avatar
Can only help with the code reading, Key on-off 3 times leaving on the third time. Watch the odometer and the codes will display there and finally a P--Done when finished. I know this works on the newer trucks and think it also works on yours.
For the cost I would try just the Map sensor and see if it makes any difference before spending the $3800 with the dealer. If that isnt the problem is should at least deduct that much from the dealers estimate and if it does fix it a cheap fix compared to the dealers quote. Maybe an APPS reset if appropriate might help also.
Just random thoughts, nothing I know for sure !!!
Old Aug 26, 2007 | 01:43 PM
Mike Perez's Avatar
Replace the MAP sensor your self for about $100. then move on if you have to.
Mike
Old Aug 28, 2007 | 08:50 PM
scor572's Avatar
Replaced MAP sensor today, and early reviews are good. After a short drive, power and response seem normal.
Old Aug 29, 2007 | 01:16 PM
fschiola's Avatar
I would still check for any codes and get your fuel pressure checked to see if you really need a lift pump. Do the pressure test ASAP and correct accordingly.
Old Aug 29, 2007 | 07:57 PM
TreeFarm's Avatar
Sounds like he might need a new dealer too.
Old Aug 31, 2007 | 04:14 PM
Traditional's Avatar
I suffered the same problem after a snow storm driving through 4' drifts. Air intake was plugged with snow. Air flow sensor was questioned, unplugged it, removed the sensor, dried it out. Reinstalled and that corrected the problem.
They may just be signing you up for the enevitable fuel pump experience.
Old Aug 31, 2007 | 08:12 PM
scottsjeeprolet's Avatar
Now go get a Fuel Pressure gauge. Gotta keep an eye on it.
Old Aug 31, 2007 | 10:42 PM
johnh's Avatar
you can buy a code reader from checker auto parts for less than 100.00
Old Sep 1, 2007 | 06:59 AM
for only $650 you can get a Smarty. It reads codes too.
Old Sep 28, 2007 | 10:41 PM
Dodge2003's Avatar
Loss of Power
My truck started losing power and seems to happen when I hit the speed of 120km. Any Ideas.
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
99gt
Mar 24, 2010 09:13 PM
choppers555
Oct 16, 2007 12:29 PM
Stevenc
Dec 28, 2004 08:29 PM
