No Power after head gasket replacement
Old Jan 14, 2008 | 09:19 PM
SC68Cuda's Avatar
Hi All,
Long time lurker, first time poster.
Have a '93 D-350 that we just put a head gasket on due to water leakage at the front passenger side corner. After reassembly, the truck started and ran, but wouldn't build RPM. Currently the truck will build RPM when warm, but barely has enough power to pull it back in the shop. My buddy has bled all the lines per the FSM, and we've looked it over for obvious air leaks, etc... there must be something newbies would miss - any help?
Will share more info once we get the old girl sorted out.
Thanks,
Steve Charette
93 D-350 CTD 5 spd
Attached Thumbnails No Power after head gasket replacement-93-d-350-corrected.jpg
Old Jan 14, 2008 | 09:26 PM
dj_souvlaki's Avatar
wow beauitufl looking truck.
any smoke coming out of the exhaust?
Old Jan 15, 2008 | 06:57 AM
blackdiesel's Avatar
Registered
Welcome to the poster world. Have you rechecked the valve settings?
Old Jan 15, 2008 | 07:14 AM
Dodgezilla's Avatar
Yup, Sounds like valves way out of adjustment to me...
Old Jan 15, 2008 | 09:18 AM
SC68Cuda's Avatar
No smoke at all, it's always been pretty smoke-free (must be time to turn it up, huh?)
Valves were set at .010" on the intake and .020 on the exhaust, per the Cummins B-Series FSM. We went back and checked again just in case, although I can honestly say we did not use the timing pin to locate the crank, just rotated the motor to get to the cam base circle. The motor fires immediately when the key is turned, and runs smooth.
It just doesn't make enough power to fall out of a tree...
Read posts from here and a couple other sites last night until I couldn't see straight. Tonight we'll be checking the following:
1. Intercooler tubing and boots
2. Exhaust obstructions
3. Electrical connections to FI pump
Does a '93 have a throttle position sensor? What about a crank sensor??
Also, there are three wires going to the FI pump... the one that looks like an oil sending unit has a loose connection that we'll replace tonight as well. If I understand correctly, that one senses oil pressure and limits engine RPM if oil pressure is low? And the other two are just for shut-down??
Thanks for the help all, I really appreciate it. My buddy has been pretty understanding about this thing plugging up his shop, but he's got work stacking up and I gotta get her out of there.
Thanks again,
Steve
Old Jan 15, 2008 | 09:40 AM
JD730's Avatar
These have no effect on engine power output, the pump is of mechanical nature.
One wire is 'hot' when the key is on, this should be blue, this wire is used for shut down. The other wire that come off of there goes to a sensor in the intake that is closed when the temp is below xx*F. The other wire goes to the other solenoid and is the KSB. There are no provisions for oil pressure shutdown on these engines the way they are installed in our trucks.
Thanks again,
Steve
Look at your lift pump, where is the lever? Is it pointing down or is it pulled up? If its down it will limit how much the diaphragm is pumping or not pumping. It needs to be in the up position so it is parallel with the ground.
RussianVolk
Jul 28, 2014 09:05 PM
jimbo486
Oct 25, 2009 11:44 AM
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
MADSEN
Oct 7, 2004 09:43 PM
