No lighting bolt on the dash board
Old Mar 20, 2023 | 07:26 AM
Rivera's Avatar
Hi to the community, I start my truck and shut down in two seconds , then the lighting bolt was no on on the dash board, I change the batteries and nothing no lighting bolt on dash , the alternator is new , I try to start and do nothing no crank , nothing , I going crazy with that electrical issue , I cannot be the only one in the planet who have that issue
Old Mar 20, 2023 | 12:14 PM
Mexstan's Avatar
Please write in black print so that we can read what you wrote.
Are you saying that there is no power on the dash? No lights when you turn the key on? Do any of the instruments work, such as the gas gauge?
What year is your truck? Any modifications?
Old Mar 20, 2023 | 03:08 PM
Rivera's Avatar
Hi , I start the truck and shut down in 2 seconds , I took the key out and try to start again the lighting bolt was off the dashboard , I put new batteries, have I new alternator , and the light bolt is not on , Al the other lights are on except the lighting , try to start and don’t crank nothing, is deleted long time ago , no electrical issues ever , my truck is big horn 08 6.7 4x4
Old Aug 16, 2024 | 05:13 AM
RanniWins's Avatar
If the truck shuts down quickly and you don’t see the lightning bolt symbol on the dashboard, here are a few things to check:
Battery Connections: Ensure the battery connections are clean and tight.
Fuse: Check the fuse related to the throttle control or electronic throttle body.
Throttle Pedal: Inspect the throttle pedal and its sensor. It might be faulty.
Wiring: Look for any loose or damaged wiring around the throttle body and battery.
ECM: The engine control module might be having issues.
If you’ve checked these and the problem persists, it’s best to get a professional to diagnose the issue.
Sizedog
Sep 7, 2018 07:20 PM
skidooer76
Feb 13, 2010 08:08 PM
S_Wilson
Jan 24, 2005 06:54 PM
signature600
Apr 22, 2004 07:30 PM
