No Light In Pyro, Just Installed
Diprocal EGT gauge light dosent work, Just installed at a shop over an hour away but closed when I picked it up. Need Help, checked wires, seem right at the back of gauge, Is there a serviceable bulb ???? Don't want to have to take it back.
I would think that they used a common hot and ground to feed al 3 lights check the bulb and then check the socket for power and ground . If you are missing power or gound at the socket work back from there. Are the other two lights on with the key or are they switched on with the headlights?
Joey-D
Dec 12, 2011 12:52 PM
zcarnes
May 15, 2006 11:42 PM
Steve5.9L
Nov 12, 2003 02:08 PM
wannadiesel
Apr 19, 2003 10:50 PM
