No Gauge lights?
Old Feb 14, 2011 | 08:17 PM
thatonedude1's Avatar
No Gauge lights?
Hey guys i have a 91 W250 cummins, The other night i was driving and thel all of the sudden all of my Guage lights went out. I have no running lights essiantley, My blinkers work when i turn them on and the low oil psi one works but none others...I checked the bulbs and they are good. Im stuck in my buddys yard and i need to go to work in 6 hrs! but i dont have a truck to drive! HELP!!
91 W250 4in Sky jacker, Sittin on 285,85,16 Eagle Alloys, 6in Dual stacks!
Old Feb 14, 2011 | 08:21 PM
Oh and i have been to auto zone and put in a new switch...Still nothing
Old Feb 14, 2011 | 09:01 PM
jhenson's Avatar
Have you verified that your fuses are good?
Old Feb 14, 2011 | 09:02 PM
Yes
Old Feb 15, 2011 | 01:05 AM
jhenson's Avatar
Almost sounds like a short somewhere if you have no running lights either. Check for frayed wires.
Old Feb 15, 2011 | 10:37 AM
Onemoparnut's Avatar
Do you have power at the fuse?
Old Feb 15, 2011 | 11:10 AM
torquefan's Avatar
When you replaced the switch, did you have a good look at the connector and make sure it wasn't all melted and the terminals still fit tight?
Old Feb 17, 2011 | 07:54 AM
200cs's Avatar
Check and see if you have a trailer harness shorting at the rear bumper area. I have seen this before on trucks of that vintage, usually after the dash and everything else has been pulled...
The running lights and dash lights typically are on the same circuit and your trailer running lights tie into that. It may not be enough to pop the fuse but still cause problems.
Also check your grounds.
Good luck.....
Old Feb 17, 2011 | 09:53 AM
infidel's Avatar
My bet is a blown fuse.
Did you check them with a meter or test light?
Many times just looking at them doesn't work.
Old Feb 17, 2011 | 10:28 AM
307Kenworth's Avatar
My wiring harness for the light switch caught on fire on my 91, new switch, harness, and I put my headlights on relays and all is well, lights work better than before.
schamran
Feb 11, 2013 08:14 PM
MoreSmoke
22
Jan 10, 2005 03:05 AM
CHarlan
Aug 6, 2003 08:40 PM
