no fuel out bleed screw
Old Jul 26, 2008 | 04:05 PM
renacolt's Avatar
Can any one give advice. My 1995 diesel 3/4 ton died. I thought I had run it out of fuel, quite possibly I had. (fuel gauge doesn't work) Now I put fuel in it, pumped the crap out of that primer pump, turned it over many times, I got a little bit of fuel out at first with bubbles in it, now nothing. I am finding that I have to lift up on the shut off solenoid to get it to engage when I turn the key on. I called a friend and he said I could only prime the dodge with the key on and solenoid up(he is a power stroke guy though). I had a problem about 2 years ago and had the solenoid and the wire to it replaced and injection pump rebuilt. Any advice on what now?
Old Jul 31, 2008 | 08:34 PM
dozer12216's Avatar
Loosen a fitting after lift pump to get priming started. Do you have a pluged filter or crimped line do you?
Old Jul 31, 2008 | 09:05 PM
rebal's Avatar
you could have a hole in the fuel system letting air in put 5 psi air in the fuel tank and look for leaks 5PSI ONLY!!!!! you dont want to pop the tank
Old Aug 1, 2008 | 01:28 AM
renacolt's Avatar
Thanks guys. I also changed the filter so I don't think that is the issue. I will try the pressure test next.
Old Aug 1, 2008 | 08:10 AM
j-fox's Avatar
Algee usually is black, is it in the tank and lines?
I had an old bread truck with the algee problem. Fuel would not flow!!
80 psi air pressure and it still fought movement. Then it finally gave in.
Ran the fuel tank low-this took several filters--dropped the tank and cleaned it.
Also the engine need to be rotated away from the cam lobe that opperates the lift pump to prime it.
jmd4993
Jun 22, 2013 07:36 AM
Deadbunny
Mar 29, 2009 10:17 PM
Bad Ramer Jamer
13
Jan 12, 2008 05:38 AM
broncobilly
Oct 30, 2007 09:35 PM
aicomp
Nov 6, 2006 01:03 PM
