No brake lights
Old Sep 1, 2010 | 10:41 AM
BobWatts's Avatar
No brake lights
Hey guys...lost my brake lights including the upper brake light on the top of the cab. Directionals,4-ways, and tail lights all work. Fuses and relay under hood are alright. Could it be the brake switch? A ground issue?
I have constant power at the pink w/blue striped wire at the connection for the switch but nothing from any of the other wires with the petal pressed or not. Too me I would think the switch is bad. I'd like to find out before I go trying to replace the switch.
Thanks guys, Bob
Old Sep 1, 2010 | 11:47 PM
BigIron70's Avatar
Cummins Guru
Sounds like a bad switch to me.
Old Sep 1, 2010 | 11:50 PM
madhat's Avatar
Administrator/Jarhead
I'd say a switch, too. Find the switch, unhook it and jumper the wires, if you can. (I'm not sure how the switch is set up on a 97, but that's what I'd try.)
polaris800sp
Nov 13, 2008 05:35 PM
jj3500
Jul 5, 2008 11:20 AM
CHarlan
Aug 6, 2003 08:40 PM
