New VP44, won't start
Old Jun 22, 2008 | 09:43 AM
Steve in Haiti's Avatar
I live in Haiti so no dealer, no part available here. Just replaced the injection pump and it won't start. Have a 2000 Dodge 24 Valve Turbo Diesel, 5 speed. After replacing pump I bled all lines, but it refuses to start. Seems like it is right on the edge of starting, have smoke coming out of the exhaust. Gave it 1 small shot of ether...it fired over, but would not run. Didn't have a code reader, finally found one, after clearing the old codes, now it is not throwing any codes. Have plugged and unplugged computer (ECM), plugged and unplugged injection pump, checked fuses and relays, did the throttle position sensor reset. Have to way to check fuel pressure, but fuel volume seems to be good and have fuel coming out of the injectors when I bled them. Is it possible the pump was calibrated wrong? HELP PLEASE.
Old Jun 22, 2008 | 11:01 AM
johnh's Avatar
it sounds like injector timing..... maybe the key was inserted wrong, there is 2 ways to insert the key...the offset has to be correct, there should be an arrow stamped on the key, the arrow points toward the pump
hope this helps....
Chaser10
23
Feb 20, 2018 03:26 PM
GizmoJoe
Feb 25, 2008 04:50 PM
13ALPHA
Dec 6, 2007 02:56 PM
IntakeRacing
Sep 14, 2007 04:45 PM
Flatty
Nov 26, 2005 08:56 PM
