Need some help with my work truck please.
Old Feb 26, 2011 | 10:55 PM
lu798welder's Avatar
My sig is the truck i'm having my problem with. I've posted this on the high performance side and haven't got any help. I don't want to be driving my truck if something is getting tore up. For the last two weeks the truck has a shake to it when taking off and it quits around third gear. I was thinking carrier bearing but I've heard the pressure plate gets wore out sometimes and cracks and warps causing a shake. Last night while driving it I noticed when I was first taking off letting the clutch out as soon as it felt like it engaged it made a popping sound. Its a val air clutch and i've had it in for going on 3 years now and never had any trouble out of it other than feeling like a 18 wheeler jumping taking off. If this is something that might be damaging my transmission or anything then i want to shut it down. Any ideas what this might be? Thanks for any help.
Old Feb 27, 2011 | 12:13 AM
RAKFIRE's Avatar
Have you checked the u joint's ? I've had u joints that the bearings stopped turning and just rocked back and forth and dug grooves into the cross. That's when the noises and shakes started. If anything I would throw in some U.S.A. made u joints in and a carrier bearing. It's not that $$$ to do and can't hurt. Unless you drop the driveshaft on your parts. Other than that Check your tranny mount bolts, and look at the drive shaft for bends, dents and missing weights. I know it's annoying to hear but, set your e brake and chock your wheels. I've seen a truck roll with someone under it, on fairly level ground. It didn't end well. If you have a lift then I'll just shut up and be envious. Hope this helps.
Old Feb 27, 2011 | 12:25 AM
Thanks I'm gonna try to change that carrier bearing out tomorrow if I can find one. I don't know if I need to shim it down a little bit since I've lifted the truck. I've only had the lift on the truck for around 6k miles so i'm thinkin maybe thats putting it in a bind maybe?
phal
24
Jul 10, 2009 04:53 AM
Mini_Donkeys
Apr 19, 2007 12:21 PM
SuperiorRam
Mar 15, 2007 03:10 AM
coupdetat
Jan 17, 2007 09:23 AM
golddusters5703
Jan 28, 2006 01:35 PM
