Need rebuilt g56
Old Apr 30, 2009 | 12:38 PM
tejas transport's Avatar
Need rebuilt g56
Tranny's making a bad rubbing noise, but when you push the clutch in it stops. Tranny man thinks it is coming from the rear of the tranny. Knowone around these parts (corpus christi area) knows nothing about them. A new one is around $5400. Any ideas? It is an 05 with 250,000 miles.
Old Apr 30, 2009 | 01:25 PM
whitebuffalo's Avatar
mine did that (but not real loudly) and it was the input shaft. was under warranty but book price on it even wasn't all that much fwiw.........
Old May 2, 2009 | 09:22 AM
Had tranny guy focus on the input shaft area. He pulled the tranny completely apart and found the bearing on the back side of the input shaft was developing a flat spot, thus giving me my noise. He is going to put a bearing kit in the tranny and put it back together. Everything else looks great for 248,000 miles he said.
thanks
Old May 6, 2009 | 11:33 AM
tool's Avatar
Good to hear you are getting some good service out of your G56!
How many clutches have you been through?
Old May 8, 2009 | 07:25 AM
Tranny like new. All new bearings and seals. $2708.00
Factory dual mass flywheel
1 oem dual mass flywhee at 80,000 miles
south bend clutch and single mass flywheel at 145,000.
Old Jun 10, 2009 | 12:44 AM
usmc5593's Avatar
I am in the corpus area and am having some 6 speed man trouble where did you take your trans? How did you like the southbend clutch, Which one did you have?
Thanks
lauranull
May 24, 2007 11:57 PM
