Need help with the following Codes
Old Aug 11, 2007 | 11:27 PM
vzdude's Avatar
DTR's 'Go to Guy'
Could be a sticking spool valve in the valve body, but haven't seen that in a while. Not real likely I guess. Yeah, quick thing would be to take it out and see if it moves freely or if its jumpy when you cycle the key on. Supposed to be "selfe adjusting" so shouldn't cause any more trouble than you are already having!
Old Aug 11, 2007 | 11:39 PM
Steverfd's Avatar
Thanks for all the help man, Gonna take it off and see what happens in the morning.
Ill post what I find, Thanks again man.
Steve
Old Aug 12, 2007 | 12:27 PM
Steverfd's Avatar
ok Removed it and checked for movement when ignition is cycled. Non at all. I tried it several times even tried it while engine was running, it just sit there. The shaft which the acuator connects to will move counter clockwise and return to the starting position when i release it. So it appears nothing is locked up with the shaft anyway.
Thanks for all your help, I think the problem is my TTVA is dead in the water, or as a saying we have in the EMS field its DRT or Dead Right There.
Thanks again
Steve
Old Aug 15, 2007 | 04:20 PM
Steverfd's Avatar
Update........................
Got the Actuator in today and installed it. Same thing. I purchased a code scanner also and it keeps coming back. Im sorta at a loss, Best I can tell there is no voltage there. All connectors look good and feel good. All Fuses appear good as well.
Let me know if anyone has any suggestions on which direction I should go.
This is really making me want to pull my hair out
Steve
Old Aug 15, 2007 | 07:23 PM
vzdude's Avatar
DTR's 'Go to Guy'
As per the PM's it looks like the cooling fan is connected somewhat to the trans TTVA. They are both in connector C112. It is near the water in fuel sensor. That is where I would head!
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
