?? need help
Old Jan 29, 2004 | 12:01 PM
BIG&BAD's Avatar
?? need help
ok here what happen
tues night my truck would not start. i thought i ran out of fuel so i put some and waited till morning to try and start it.. i had to bleed out the air, and got it started, parked it for a few hours and tried it again later wednesday night and it didnt start?
i figure i try it this morning and take it to a shop, but a funny thing happed it started.. but i dont have any cruise control and my brakes arent working correctly.
what the heck is going on with my truck?
Old Jan 29, 2004 | 12:05 PM
BIG&BAD's Avatar
also my abs and brake light came on
and the brakes, work fine then get a hard petal and the truck just kindof slides to a stop, then work fine again...
Old Jan 29, 2004 | 12:59 PM
BIG&BAD's Avatar
update
it's now noon and my truck wont start again
going to bleed the system and take it to a shop
please guys help me out here??
does it sound like my lift pump is going
it runs fine when it starts??
thanks
bruce
Old Jan 29, 2004 | 01:06 PM
BIG&BAD's Avatar
ok will theres fuel and no air but i cant get to start
i dont what to do?
Old Jan 29, 2004 | 01:27 PM
BIG&BAD's Avatar
thinking about it, my truck starts ok when it was pluged in but now thats its been sitting it not starting.. could my grid heater be cause my truck not to start??
Old Jan 29, 2004 | 01:46 PM
Craig93's Avatar
Are ya tired of having a conversation with yourself?
Is it really cold down there?...really?
Does your alt dive down during the pre-heat cycle?...does your wait to start light corresond to this? Could be something in your grid heaters...do a search on this.
Sounds like you have a loss of vacuum, could be a line problem or v-pump prob. Check all your lines first.
So did you take it to a shop a beg for mercy or did you try and bleed it yourself?
Were you low on fuel to begin with? Have you changed your filter lately?
What is your status today?
Old Jan 29, 2004 | 01:47 PM
Junk Yard Dog's Avatar
B&B, theres a lot of things that don't make sense, but is your fuel shut off sel. pulling the plunger up. Have someone sit in your truck and hit the starter and feel if the sel. is working. From what you are expl. it seems to me you have an electrical prob. Check all fuses, inside and out in the PDC. See if you can hear the fuel shut off relay on the firewall clicking. That should give you something to do for a while till someone else chimes in.
Rick
Old Jan 29, 2004 | 02:17 PM
BIG&BAD's Avatar
(1) yes im tired of talking to myself or should i say writing to my self
i bled the lines myself
its not cold today its about 47*
as far as i know that grid heaters are working
im going to have my lines checked soon
learned it could be dirty
yes i was low on fuel, and my filter should still be good
i changed about 4000 miles ago
status is whats written above
thanks
for the reply craig
Old Jan 29, 2004 | 02:18 PM
BIG&BAD's Avatar
thanks rick i'll check that out
Old Jan 29, 2004 | 04:01 PM
Steve Roseman's Avatar
Be sure to check the infamous blue wire going to the positive battery connection.
With all the different symptoms, it's hard to tell what's going on.
Old Jan 29, 2004 | 05:22 PM
BIG&BAD's Avatar
whats the blue wire i dont think i heard of that one?
Old Jan 29, 2004 | 07:30 PM
The blue wire provides the "pull" power to your fuel solenoid. If you turn your key to the start position and the solenoid doesn't pull up, but stays up if you push it by hand, there's a good chance your wire is off or corroded. I've heard many stories of people buying a $400 solenoid when the wire or the relay is the problem.
Old Feb 2, 2004 | 10:44 AM
BIG&BAD's Avatar
will i got my truck running
the relay was bad and also the shut off solenoid
thanks for all the replys
i really appreciate it
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
coupdetat
Jan 17, 2007 09:23 AM
