need help on a 2001 24 valve
Old Apr 25, 2007 | 04:14 PM
Tony R's Avatar
i have a serious problem with oil running out of the breather tube on the front of the motor its proably used a gallon since sunday night. I took the breather apart and pack4ed it with steel wool to make it harder for the oil to get out but hasnt really helped changed oil filter from a napa gold to a mopar 285 didnt help heard lost brakes friday night for about a minute had brake light and abs light come on pushe on fused relay for the pump and light went off any ideas
Old Apr 25, 2007 | 06:41 PM
starkey's Avatar
Well, if your trucks throwing a gal of oil out through the puke bottle, something definatley wrong! Have you emptied it at every oil change? Maybe overfilled a little?? You lost brakes also? What are you drivin? 4x4? I know my truck lost brakes for a while, abs and brake light were on and then i lost my abs hub. Sounds like you might just have a loose ground our something..
By the way, Welcome to DTR!! Fill out your signature in your user control panel so we know what your working on!
Old Apr 25, 2007 | 07:05 PM
fbx22's Avatar
packed it with steel wool
Old Apr 25, 2007 | 07:17 PM
Tony R's Avatar
its a 4x4 auto i thought maybe i had a vacum leak causing excessive crankcase pressure i just packed it with a finer grade steel wool to try to keep some of the oil in because for those of u who never took one apart coarse steel wool is what is in there from factory
Old Apr 25, 2007 | 07:45 PM
Tony R's Avatar
ok i was watching the oil coming out of the breather i pulled the oil fill cap off and then u could hear the air release and the oil quit coming out any ideas
Old Apr 25, 2007 | 07:49 PM
fbx22's Avatar
I see..Ive never taken one apart. So its just steel wool in there, interesting.
Old Apr 25, 2007 | 08:32 PM
Tony R's Avatar
i was just trying to figure out what could be producing air in the motor its a great time for this to happen pulling season is a month away and i still got the engine to install in the 94 what is the best oil filter you can put on one of these the 24 valve
Old Apr 25, 2007 | 09:09 PM
turbomike's Avatar
When a quart comes out the breather tube does the oil level on the dipstick drop an equal amount ? Is it running ok ? Is the coolant level ok and does it look normal ? Any unusual smoke coming out of the exhaust ? Has the mileage changed ? Does the turbo sound like it usually does ?
Old Apr 25, 2007 | 09:29 PM
Tony R's Avatar
yes everything is normal no power loss etc im starting to look toward the service bulletin on doing away with the breather going to check on it at dodge tomorrow i think its always been leaking a little now its getting worse no codes thrown by comp checked with my mac tools scanner im lost
Old Apr 25, 2007 | 09:40 PM
fbx22's Avatar
I use fleetguard stratopores. I think thats what most reccomend.
Old Apr 25, 2007 | 10:36 PM
ratsun's Avatar
I just read thru this quickly but it sounds like your vacuum pumps leaking badly
Old Apr 25, 2007 | 11:03 PM
XLR8R's Avatar
I agree - especially if the oil level has not increased in the sump.
Old Apr 26, 2007 | 04:28 PM
rattlerbob5.9's Avatar
vacume pump or turbo seal if you are building cranckcase pressure that bad
Old Apr 26, 2007 | 04:54 PM
Tony R's Avatar
ok how do u tell if the vacum pump is leaking that bad cause everything else works fine if this makes sense why does a 12 valve have a breather in the tappet cover and the service bulletin actually relocates it on a 24 valve in the exact place its always leaked there since ive had the truck on the front but getting worse i think the vale guides are getting wore and causing charger pressure to enter the valve area dodge wont cover it and its 310.00 for the kit i think ill just put a breather on the valve cover or put a 12 valve tappet cover on there anybody got one for sale
Old Apr 26, 2007 | 05:13 PM
johnh's Avatar
i'm not sure i understand how a leaking vacuum pump can pressurize the engine
some body tell me how.... i am serious i'm not trying to be smart
