Need ECM
Old Feb 28, 2006 | 03:05 PM
ridofpwrstroke's Avatar
Need ECM
where is the cheapest place to get an ecm? My two codes 0221 and 0237 led me to the computer. Any info?
Old Mar 2, 2006 | 11:27 AM
RCW's Avatar
RCW
The problem is the drive by wire throttle pedal position sensor. You will be wasting your money on the ECM.
Old Mar 2, 2006 | 01:26 PM
I keep getting a check engine light. I reset, it comes back on instantly. My computer says my intake air temp is 293 degrees. It was 5 degrees outside. I dont think it is my TPS, plus I dont get a tps code. Do you still think it is my TPS after the symptoms I have? Bob Wagner is trying to find a ECM for me. I am trying to be patient.
Old Mar 3, 2006 | 03:39 AM
RCW's Avatar
RCW
If you are getting codes other than those associated with the TPS you may need the ECM. However, unless you have been jump starting other vehicles or welding on your truck with the battery grounds connected I would first check to be sure you have not accidently grounded the temperature sensor wire, the battery temp sensor wire, or the AC pressure sensor wire. If any of those go to direct ground it upsets the 5.8 volt bus in the ECM and will create the problem you describe. Here is a rebuilder that likely has exchange units 1-888-664-8787, or these guys will 1-800-557-8674 should you need an ECM.
ratat98
Sep 18, 2016 07:34 PM
6spd05Dually
Mar 12, 2011 12:19 PM
jrussell
17
Sep 17, 2007 06:38 PM
Ohio Joe
Jul 12, 2004 12:13 PM
