In The Middle Of A Rotor / Pad Change
Old Jun 7, 2007 | 05:50 PM
EverydayDiesel's Avatar
My question is... how do i get the rotar off?
I have the brake caliper and pads off but the rotor doesnt want to budge.
Is it the BIG center bolt in the middle of the axle?
Anyone know what size that bolt is...if thats it.
Old Jun 7, 2007 | 07:30 PM
merrillr4's Avatar
On your year truck you won't need to take off the big nut. I changed my front rotors and pads out about 3 months ago and had the same problem. I took a can of brake cleaner and sprayed it from the backside. You have corrosion built up in there. You need to break that bond to get the rotor off. It took some time with the cleaner but after about 1 hour they finally started to come loose. Good Luck.
Old Jun 7, 2007 | 08:15 PM
johnh's Avatar
if you have a propane torch ,a little heat should do the trick. just make sure you heat it evenly to keep it from warping if you are going to reuse it
Old Jun 7, 2007 | 09:37 PM
a BIG hammer did the trick...now to change the pads
Do I have to loosen the star bit? How do i get the old pads out?
Old Jun 8, 2007 | 08:57 AM
someone has to know....
do i have to take the star bits out also?
Old Jun 8, 2007 | 11:39 AM
Need95-00CTD's Avatar
I guess the 24 valves are different than the 12 valves. I had to pull the axle retaining nut, and the hub to get the rotor off...what a PITA. You should be able to just pull the caliper and slide the pads off, but post a pic and one of us can probably help.
Old Jun 8, 2007 | 12:34 PM
b4wheeler's Avatar
Just remove the two #47 torx bolts and that will let the calipers come off. Then it goes back the same is it came apart.
Old Jun 8, 2007 | 08:36 PM
well i got the front rotors and pads changed
i started on the back and broke the 13mm bolt inside the bracket.
I wasnt even turning it that hard. where can I get the outer bracket...not the one with the piston but the one you slide the pad into?
i dont really want to run it with one bolt.
tywebb3
Apr 4, 2009 12:03 AM
JoeDiesel
Nov 3, 2008 10:46 PM
EverydayDiesel
Nov 9, 2007 06:49 PM
Sailpipes
Mar 13, 2006 09:54 AM
belfert
18
Mar 24, 2004 11:53 PM
