Map sensor problem
The MAP on the diesel should generate a voltage of 5 volts plus or minus a fraction. This is measured with the key on, and on the orange wire to ground.
The other check that is necessary is the continuity between the black/light blue wire to ground. I there is no continuity, have the ECM checked as the MAP is grounded through the ECM.
Check both wires from the harness side of the connector.
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
Booost Almighty
Jan 1, 2006 01:41 PM
