low fuel pressure
low fuel pressure
Installed Edge/with attitude today and im only getting 4 p.s.i at idle.. Replaced fuel filter and no change in pressure.. I have been getting dead pedal recently. Could it just be the lift pump???? The lift pump is running Wheh i bump the starter...
Number 1 - you should have a mechanical fuel pressure guage mounted in the cab - this will verify the reading from the Edge box
Number 2 - you should scan the truck for codes with an OBDII scanner....dead pedal is usually a good sign that the vp-44 is on its way out (but not always).
You could also try to reset your APPS....but that wont cure your low fuel pressure. You definitely need a fuel system upgrade.
Just because you can hear the LP run when the starter is bumped, doesnt mean that its is moving enough fuel to lube and cool the injector pump.
BTW, welcome to DTR....
so what would your suggestion be for an upgraded fuel system...
i have a 01 3500...and i have had the same problems..tach goes to 0
and loss of power...
i am upgrading to a fass 150gph lift and a new stock injector pump right now...
is there anything else i should replace or check out?
jwb600
14
Jan 28, 2008 03:26 AM
bc3
Dec 1, 2007 10:19 PM
mudwisr2
Sep 25, 2007 07:04 PM
Spooler
Feb 12, 2006 11:43 AM
