Loss of power
Old Jun 10, 2004 | 03:49 PM
BigCarl's Avatar
Check the crank sensor. On my previous 24v truck, I had a crank sensor go out and the truck would go into limp mode and drive exactly as you have stated.
Old Jun 10, 2004 | 04:31 PM
jigdog's Avatar
you may want to try a apps reset.it helps power and mileage sometimes. do a search on apps reset and it will show up it real easy to do it made my truck run better.
Old Jun 11, 2004 | 10:41 AM
TJinTX's Avatar
I've reset the APPS about a dozen times now, hoping that it just might work for me this time . No luck.
This thing isn't smoking, and it's not making any strange noises. I replaced the crankshaft position sensor about 100K miles ago or so, but I think I'll get another one, as BigCarl mentioned. I'll let y'all know if that fixes it
Old Jun 11, 2004 | 11:03 AM
sherod's Avatar
Sounds like a friends 99. Would only make it to about 35 mph. Barely move. No codes to be found. Turned out to be speed sensor. Don't understand why no codes, but there ya go.
Good luck
Ed
Old Jun 11, 2004 | 11:40 AM
TJinTX's Avatar
Good luck
Ed
How on Gods green earth did you guys diagnose that?????????
Thanks for the good luck wishes...I dang sure need it.
Old Jun 11, 2004 | 11:44 AM
sherod's Avatar
Well, I hate to say it, but a neighbor who specializes on the PSD diag it. Funny part was, he had the sensor sitting on the bench in his home shop. I can't say what shop he works in, but he dang sure is handy.
Ed
Old Jun 11, 2004 | 11:37 PM
thumper 549's Avatar
which sensor was it????
Old Jun 23, 2004 | 05:17 PM
fire1355rescue's Avatar
this may sound pretty stupid....but you might take a look at the hoses coming out of the intercooler....i am pushing ALOT of power and sometimes the hose on the bottom will blow off causing -0- boost....dodge did have a problem with the lower boost hose rubbing on the fender and eventually making a hole...just a thought before you spend a small fortune
Old Jul 6, 2004 | 09:14 AM
TJinTX's Avatar
Thanks to everybody for your help and suggestions. I wanted to close the loop on this, and post the solution in hopes that it will help someone else.
Finally, the big, bad Cummins lives again! I changed the MAP sensor, and she came to life. Took all of 5 minutes to change, and about $50 for the sensor, bought from Cummins. The dealer wanted $107 . Only tools needed were a 1-1/4" deep socket, and short extension.
Thanks again to everyone that replied. This site is truly the best I've found when it comes to helping someone. Keep up the good work!
Old Jul 12, 2004 | 02:55 PM
Cumminsdude's Avatar
Do you have the part number for the map sensor. The cummins part number?
Old Jul 12, 2004 | 03:34 PM
TJinTX's Avatar
I'm sorry, but I don't. I threw away the receipt, as well as the box. I had to give the guy the serial number off my engine to get the right one.
Sorry I couldn't help.
RHC
Aug 12, 2019 03:32 PM
tntk9
Nov 20, 2012 07:09 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
Ranger 2/75
Mar 16, 2006 05:07 PM
jdcott1
Oct 20, 2002 11:48 PM
