Losing Power And My Tach!!!
Old Dec 14, 2007 | 10:45 AM
OGDAWG0680's Avatar
Ok I Have A 2001 Dodge 2500 And Wht Is Happening Is After My Trcuk Warms Up I Lose My Tach...once This Goes Out I Lose All Power In My Truck I Mean That It Still Runs And Everythang It Just Doesnt Have The Same Kick That It Should..almost As If You Unplug My Chip...along With This My Check Engine Light Is On All The Time...i Have Already Taken The Batt. Cabales Off And Tried To Reset It But It Just Came Back On A Litlle While Later...i Need Help A.s.a.p.!!! I Was Told By Somebody That My Truck Was Going Into Limp Mode..if Thats The Case How Can I Get It Out....
Old Dec 14, 2007 | 11:40 AM
fade94's Avatar
Any codes? Turn the key on and off 3 times without starting. Watch the odometer. It will show the codes.
Sounds like cam position sensor to me. Pain to replace. Runs about $50-60 depending on where you get it.
Old Dec 14, 2007 | 11:41 AM
John Faughn's Avatar
You need to get the codes before you clear the codes , on that yr you may need a scanner to do either .
If your loosing your tack , check the crank sensor , but you need to do proper testing , get codes .
Codes tell you where to start testing , they do not necessarily tell you whats wrong .
Old Dec 14, 2007 | 11:49 AM
fade94's Avatar
The 01 gives the codes with the key on/off trick. 01 does not have crank sensor. CTD went with a cam sensor. I have already done this repair to my 01'.
Old Dec 14, 2007 | 01:10 PM
OGDAWG0680's Avatar
ok i just ran the codes on my truck and all i got was a...P1693 code
Old Dec 14, 2007 | 04:38 PM
1693 comes up as DTC detected in companion with JTECMOD , I do not have any more at my figure tips for that , I am not familiar with this .
Old Dec 14, 2007 | 04:42 PM
OGDAWG0680's Avatar
how can i tell if it is my cam position sensor??? obviously there is no code for it but is there a fuse or is it one of those things u got to take apart to look at
Old Dec 15, 2007 | 12:03 AM
woligator's Avatar
my cam sensor whent bad about 3 months ago and i lost my tach,dead pedal whit not power..i was sure my vp44 was toast but as soon a replace the sensor and cleared my codes all power was back no codes since
97dodgeram2500
Sep 16, 2010 07:31 AM
oliver92
Jan 17, 2010 04:37 PM
tonyjsan
Jun 16, 2003 12:58 PM
Bo
Jan 11, 2003 08:32 PM
