Losing power @80mph
Old Oct 25, 2004 | 01:02 PM
ryanofire's Avatar
Losing power @80mph
Around 80 mph the 1999 2500 4x4 cummins seems to lose all pulling power. Than once it slows to 65 mph it regains all power. The odd thing is that it dosen't seem to do it all the time. I have changed fuel filter and cleaned the k&n air filter. I have watched all the gauges on every time this has happened. All in the good no changes what so ever. The best way to describe what happens is it's like the throttle and the motor stop communicating until it gets back to 65 mph. This has almost got me in several wrecks on the interstate you can imagine how fast the truck slows when you lose all power. This has got me stumped!!
Old Oct 25, 2004 | 01:04 PM
jermey1980's Avatar
what mods do you have
Old Oct 25, 2004 | 01:06 PM
ryanofire's Avatar
no mods
Old Oct 25, 2004 | 02:19 PM
SBishop's Avatar
What are your gauges reading?
Old Oct 25, 2004 | 02:25 PM
ryanofire's Avatar
tac-2100 oil preasure-60 temp around- 180 volt-14
Old Oct 25, 2004 | 03:28 PM
jdeereboy's Avatar
What gears do you have? Mine has 4.10's and I doubt the rev limiter will let mine go past about 80.
Old Oct 25, 2004 | 03:54 PM
ryanofire's Avatar
Old Oct 25, 2004 | 04:11 PM
SBishop's Avatar
Check for boost leaks at your intercooler hoses.
Old Oct 25, 2004 | 06:38 PM
rockwithjason's Avatar
You might want to look at the APPS also. Others have reported dead spots in the pedal causing similar complaints.
Old Oct 25, 2004 | 07:09 PM
RCW's Avatar
RCW
I would suspect a bad lift pump that is unable to keep up with fuel demand at higher loading.
Old Nov 29, 2004 | 06:58 PM
mr T's Avatar
80 mph?? why do u need to go that fast?? and ur only running 2100 rpm at that speed?? how much are u pulling anyhow??
Old Nov 30, 2004 | 08:55 AM
nitrousn's Avatar
do you have a fuel pressure gauge? if not you had better get one. if you are in fact running low on fuel pressure you will hurt the injection pump.
BossHogg
14
Aug 6, 2006 12:36 PM
Stingerpup
May 18, 2006 10:26 PM
tonyjsan
Jun 16, 2003 12:58 PM
Bo
Jan 11, 2003 08:32 PM
