Loose Fitting On Rocker Arm
Old Apr 7, 2008 | 11:17 PM
izzwardo's Avatar
I went to install new valve cover gaskets and I noticed this aluminum rivot on the rocker arm is loose. I tried to see if it would come all the way out but I could'nt get it to come out. It is just loose. SEE PICTURE. Do you think this is bad?
Old Apr 8, 2008 | 11:08 AM
JD730's Avatar
Thats there to plug the drilled hole for oil lube to the rocker arms. Not something I would want falling out, you would loose oil to that set of rocker arms.
Old Apr 8, 2008 | 05:18 PM
RCW's Avatar
RCW
I would pull the arm and pivot and either peen the center of the aluminum plug to tighten it, or replace the unit. You do not want it rattling out.
Old Apr 8, 2008 | 06:41 PM
izzwardo's Avatar
What do you meen peen?
Old Apr 9, 2008 | 03:55 PM
Peen = beat on it with a hammer.
OUTDOORSMAN
Jul 26, 2010 10:30 PM
SilverSootXpres
Oct 7, 2007 11:46 PM
scout98
Jun 24, 2007 08:23 AM
West Coast
Oct 16, 2006 02:16 PM
Lary Ellis (Top)
Feb 23, 2003 01:10 PM
