Lights fade in & out
Old Dec 19, 2006 | 04:15 PM
zc4life's Avatar
While running my truck lights dim and then get really bright. The same can be said about the idile of the truck. It will idile low for a little bit then the idile will go up. Truck idiles @ 750rpm. Any help would be appreciated.
Tree
Old Dec 19, 2006 | 04:17 PM
Clunk's Avatar
All the time?
Old Dec 19, 2006 | 04:44 PM
Gunrunner's Avatar
I would have to say its your grid heaters cycling if it only does it when its cold
Old Dec 19, 2006 | 05:12 PM
Racer9's Avatar
If only doing it when the motor is cold, it's the grid heaters cycling, and it's normal.
If doing it when the motor is warm, it may be the A/C cycling, which will happen if the defroster setting is on. Turn the heater control to floor, and it should stop.
If the grid heaters are cycling when warm, you have a problem to fix.
Old Dec 19, 2006 | 07:39 PM
zc4life's Avatar
All the time. That's what I was afraid of. Would this have to do with it not starting? Thanks for all the info.
Old Dec 19, 2006 | 07:56 PM
zc4life's Avatar
Say fellas, Do the grid heaters sound like an electric fuel pump?
Old Dec 19, 2006 | 08:15 PM
Racer9's Avatar
The grid heaters have no sound, they are very similar to a toaster, without the bread popping up.
I think you are hearing the A/C clutch kicking in. Turn off the defrost.
Old Dec 19, 2006 | 08:17 PM
zc4life's Avatar
Check. No defrost on. Thanks
Joker12valve
Aug 2, 2007 01:41 PM
Herrin811
Apr 21, 2006 06:05 PM
iweb
Aug 13, 2005 11:27 AM
Jambbii
13
Apr 5, 2004 10:19 PM
Jambbii
Dec 30, 2003 04:17 PM
