Does your fade work?
Old Aug 10, 2005 | 10:10 AM
iweb's Avatar
I have the 6 cd changer with infinity and my speaker fade doesn't seem to work right. When I go all the way forward I hear the front speakers good, then when I go all the way to the rear speakers I still just hear the fronts and if I open the back door I can hear music in the rear speakers. Any ideas? Thanks.
Old Aug 10, 2005 | 10:17 AM
iweb's Avatar
Might help to add in my signature.
Old Aug 10, 2005 | 11:18 AM
nickleinonen's Avatar
i don't know if the tweeters on the dash are connected to the fader...??? if they are not, all it will do is fade back/forth between the door speakers...
Old Aug 11, 2005 | 11:39 AM
handymantim's Avatar
I have the same sound system you do and I just went out to check the fade. When I fade to back the sound goes to the back and there is little if any sound in the front and vice versa. I'd say you have some crossed wires somewhere.
Did you try adjusting the balance left/right/center?
Old Aug 11, 2005 | 01:35 PM
iweb's Avatar
Yep I tried everything and the balance works fine just not fade. I tried again this morning just to make sure I was remembering right. Thanks handymantim for checking.
Old Aug 11, 2005 | 05:00 PM
Lee S's Avatar
Mine works like handymantim's. I have it set for just a little more coming from the back speakers than the front and it sounds nice.
Old Aug 13, 2005 | 11:27 AM
v12xke's Avatar
There is a TSB out for crossed wires in the header that plugs into the head unit. The TSB shows which wires are involved, and from what I've read the radio pops out with little effort. Since you are still in warranty, I would take it in. I thought I needed the TSB. Took two trips, but they replaced the tweeters in the dash which fixed my problem. I didn't have the fader problem though, my sound was muddy and I could not use any bass at all without distortion. Fader works fine here.
Joker12valve
Aug 2, 2007 01:41 PM
zc4life
Dec 19, 2006 08:17 PM
Herrin811
Apr 21, 2006 06:05 PM
Jambbii
13
Apr 5, 2004 10:19 PM
Jambbii
Dec 30, 2003 04:17 PM
