It's Back...... Kinda?!
Old Mar 18, 2004 | 07:34 PM
Stamey's Avatar
Or they contract in the cold, and expand with warmth, and seal the leak.
Chris
Old Mar 19, 2004 | 07:13 AM
desertram's Avatar
That's what I was trying to mean, I mean say, I mean, yah what he said.
Old Mar 23, 2004 | 09:39 PM
desertram's Avatar
Okay here we go again.
This morning parked uphill in the driveway with about 1/8 tank of fuel I had the no start problem. As suggested I unplugged the LP and it cranked about 2-3 seconds and fired up. I let it run for a few seconds and shut it down. I hooked the LP back up and let it run for 10-15 seconds and tried to start it. It cranked slightly longer than without the LP, 4-5 seconds befroe it started. I checked for air in my loop before I started it, nothing, and nothing after starting. When it did start with the LP the seconded time, I got a big puff of white smoke then black.
No according to your suggestions, this means my VP is bad, the fuel timing sleinoid. Is that something that can be replaced without replacing the VP.
Still no codes. I'm afraid to take it to the dealer for fear they will keep it for 2 weeks and not find a problem.
I filled up, will see if tank level makes a difference. Started and ran fine the rest of the day.
AGGH!
Old Mar 24, 2004 | 07:36 AM
dsldan's Avatar
The dealers have a test they can do on the vp44. I think they unplut the wires from the vp44 ant place a tester on it and try to start it. If it starts and runs then its the pump. Test takes bout 15 minutes
Old Mar 24, 2004 | 01:11 PM
desertram's Avatar
This morning with a full tank, no problems. This sounds to me like an air leak but I have seen absolutly no bubbles in my clear test line. Does the head on the VP make a difference if it is bad? If so why does it start without the LP?
Gauges should be in tomorrow.
sallyman1
Mar 30, 2009 10:40 PM
JoshPeters
Apr 3, 2005 08:13 AM
warden
Feb 7, 2003 07:22 PM
xj2extreme
18
Jan 23, 2003 07:34 PM
Shovelhead
Oct 5, 2002 10:48 AM
