Intake Grid Heater
Old Nov 8, 2010 | 08:52 AM
coyoteduster's Avatar
Intake Grid Heater
I have a 2003 Dodge 2500HD with the cummins diesel. I noticed last winter it was getting more difficult to crank in cold temps so I began researching the problem. I noticed the voltage was not discharging as much as my 2008 Dodge when the grid heater indicater on the dash was on. I checked the voltage to the grid heater relays, all good so I assumed the grid heater was the culprit. After a few hours work and $175 investment, my problem still remains. Everything seems to work fine, when the ambient temp is below 60 degrees the grid heater cycles on, at least according to the instruments, but the voltage still does not discharge but just a little. The indicator goes out as it should and the voltage moves up slightly but the truck will not crank unless I have left the block heater plugged in all night? Any ideas.......??????
JD
Old Nov 8, 2010 | 09:01 AM
Adaminak's Avatar
/Could be a lot of things, but check the easy stuff first. Batteries charged and holding a charge? Ground wires clean and tight? Fuses and relays good? IIRC, the grid heater is controlled via ECM on 03 and up trucks, so worst case is you've got a glitch in your programming that isn't sending full juice. I don't think that's likely, and your biggest culprit is probably a bad relay or corroded wiring.
Old Nov 8, 2010 | 09:05 AM
thanks
I will follow your advice, batteries are brand new and strong, maybe a bad ground or connection is the culprit.
THANKS!
Old Nov 8, 2010 | 09:46 AM
johnh's Avatar
THANKS!
i have found that the connections on the relays are not the best, on mine i crimped them with a pair of pliers to tighten them up, after that no more problems
Old Nov 8, 2010 | 09:50 AM
infidel's Avatar
The grids themselves rarely fail, in fact I've never heard of one failing.
90% of the time the problem is the relays, rest of the time it's the intake temp sensor, connections or the fusible link at the battery.
Everything you ever wanted to know about grids> http://dodgeram.org/tech/dsl/trouble...niford_htr.htm
Old Nov 8, 2010 | 09:55 AM
Smile thanks!
Thanks for all the valuable info, looks like I need to get started improving some connections and grounds! Thanks for the great tips!
JD
Old Nov 8, 2010 | 10:05 AM
1-2-3's Avatar
Just a plain ole guy
Probably just weak batteries and bad connections.
CTD_Neil
Mar 20, 2007 11:49 PM
NHRedneck
Dec 6, 2006 06:28 AM
jellis
Oct 24, 2006 07:06 PM
matador
Jul 27, 2005 08:24 AM
TE-44
Apr 14, 2004 11:38 AM
