installing a FP guage
Old Dec 16, 2006 | 09:43 PM
NGA Ram's Avatar
well i was gathering all the parts to install my mechanical fp guage today. When it came down to the needle valve i couldn't find one. Went every were. The people knew what i was talking about but didn't have it. Can i use a ball valve or does anyone have any suggestions?
Old Dec 16, 2006 | 09:46 PM
DL1221's Avatar
They can be hard to find, try your local NAPA, or buy one here:
http://www.vulcanperformance.com/ser...h-8-NPT/Detail
or here:
http://www.sourceautomotive.biz/needle_valve.htm
Old Dec 17, 2006 | 02:30 AM
Rauschbo's Avatar
....try your Yellow pages, I found mine at a plumbing supply house - call them first and tell them what you are needing one for, they should be able to hook you up;
Old Dec 17, 2006 | 06:15 AM
Geico266's Avatar
Burden's Surplus Center has them.
http://www.surpluscenter.com/sort.as...needle%20valve
Old Dec 17, 2006 | 11:52 PM
Dr. Evil's Avatar
Cant use a ball valve....u need a needle valve to dampen the pulses.
Old Dec 19, 2006 | 09:47 AM
b.lee's Avatar
Originally Posted by Geico266
which exact needle valve does it use? there are a ton of them at that link.
and all mech. FP guages use the same one?
im trying to get everything i need for a FP gauge.
Old Dec 20, 2006 | 04:35 AM
Rauschbo's Avatar
....just about any valve will do, one with a locking or set screw would be best....
Draw up a diagram of what you need - valve (where it splices into the fuel line), step-down connector to the line going to the gauge, connector to the gauge...and take it to your plumbing supply house - they can fix you up.
Note: Use thread dope, NOT tape, while some have been successful with the tape, there are also Bad Things that can happen if you get pieces in the fuel stream....
betsycam
Sep 9, 2004 02:13 PM
betsycam
19
Aug 19, 2004 08:30 AM
GreyBoy
Oct 28, 2003 05:55 PM
dkinzer
Oct 2, 2003 01:15 AM
cLAYH
Aug 27, 2003 01:50 AM
