injectors
Old Aug 3, 2009 | 05:23 PM
hot shot's Avatar
injectors
can anyone explain how to find a bad injector.at the dealership they capped the lines or something and figured it out.is there a way for this broke bastard to figure it out myself instead of taking it to the dealer.
Old Aug 3, 2009 | 09:31 PM
rich's Avatar
make a cap out of an old injector line in order to check each injector
Old Aug 3, 2009 | 09:45 PM
hot shot's Avatar
where do you put the cap on?where it comes out of the rail.i dont mean to sound stupid but i hall freight with my gooseneck and i dont want to screw up the truck.no truck no paycheck
Old Aug 3, 2009 | 09:53 PM
mwdean's Avatar
a high quality scan tool can perform an injector kill test which is usually enough to find a dead inj. leaking is a lot tougher to isolate & may require capping, which is done at the rail
Old Aug 3, 2009 | 09:57 PM
BigIron70's Avatar
Cummins Guru
You can also use temp probe on exhaust the coolest one is the missing cylinder. If you have access to a DRB it has test function for injectors % of contribution and injector kill function. Capping injectors at the rail takes a long time and you have to remove the line, don't ever try to bend these lines or you will be buying a new one.
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
