Impact Wrenches
Old May 24, 2007 | 11:46 PM
J Turner's Avatar
Impact Wrenches
I am heading to the store in the morning to buy an Impact Wrench to remove the axle nuts on my 2001 2500 4X4 QC.
Will a 500 ft.lb. wrench be enough, or should I be looking at the 600 ft.lb. model?
I can get an Ingersol Rand kit with the Impact Wrench and Ratchet together for $139 at Lowes. It is the 500 ft.lb. IR.
Thanks,
JT
Old May 25, 2007 | 07:37 AM
Toto's Avatar
500 lbs more than eneogh.
Old May 25, 2007 | 08:30 AM
D2 Cat's Avatar
Need to consider the air compressor you have. The impact tool can only do what the air provided allows. The larger tools will need larger hoses even if the compressor will provide enough air.
Old May 25, 2007 | 11:21 AM
TonyB's Avatar
Lug nut torque (on my '06) is 145 ft-lb. The '01 may be different. My IR 250 ft-lb impact spins them off just fine!
HTH
Tony
Old May 25, 2007 | 06:52 PM
infidel's Avatar
Now you need to get a torque stick to go with your new impact wrench
http://www.torquestick.com/cart/cust...0&cat=1&page=1
Old May 25, 2007 | 07:21 PM
Dr. Evil's Avatar
They also have specific impact wrenches that are JUST for lug nuts.
Old May 25, 2007 | 08:24 PM
J Turner's Avatar
Thanks, but
I'm using it on the HUB NUTS, not the LUG NUTS. I torque the lug nuts by hand, wouldn't think of running them down with the impact.
I picked up an Ingersol Rand kit with a 500 ft.lb. Impact Wrench and an Air Ratchet for $139 at Lowes. Guess I'll find out how they work in the morning after I finish my 12 hour shift here.
Old May 26, 2007 | 02:03 PM
infidel's Avatar
I used to use a torque wrench but using a torque stick and checking with a torque wrench they have always been 100% right on. Quit wasting my time with the torque wrench.
Old May 26, 2007 | 10:43 PM
mr T's Avatar
i just played around today with the front end..took off the front axle nut and the 4 12 point bolts behind the hub....axle nut came off with a 3 foot extension without any issues...the bolts behind the hub had to be heated and no problems either...all studs had to be torched to be punched out...if you're trycing to loosen the 4 nuts and/or punch out the studs then make sure u have a torch handy or else it may not happen
but maybe my truck's just old and has had alot of salt abuse but still be prepared...heating it makes it quite easy
Old May 27, 2007 | 01:33 PM
Red3quarter's Avatar
I like the IR impacts and Chicago Pneumatic impacts alot, all the ones I've used work very well. But now my favorite is the Snap-on xt7100 impact wrench. It puts out 700 ft.lbs on tq and doesn't have a problem busting loose stubborn bolts. I got the snap-on one at work and use it in place of the 3/4 impact sometimes.
http://buy1.snapon.com/catalog/item....group_ID=19826
sallyman1
Feb 8, 2009 09:05 PM
NotEnufGarage
Jul 30, 2008 08:32 PM
bigragu
Dec 28, 2006 11:33 PM
$BANK$rupted
Aug 2, 2006 12:16 PM
