imjector torque????????
Old Jun 28, 2008 | 09:56 PM
07dodge's Avatar
Injector torque????????
What is the torque on the common rail injectors and the feed tubes????? help me out
Old Jun 29, 2008 | 10:18 AM
tractorguyacb's Avatar
as per mitchell this is the insatll procedure for the high pressure fuel lines
1. Tighten nuts at high pressure injector connector nut at cylinder head. torque nut to 37 ft.lb.
2. Tighten all fuel lines at rail. Torque nuts to 27 Ft.Lb
3. Torque the fuel injector solenoid nuts to 11 inch pounds
Hope this helps,
Harold
Old Jun 29, 2008 | 07:12 PM
JWH_03_Dodge's Avatar
not sure if its the same as my 03, but make sure you get the sequence right,
Install fuel injector holdown clamp (mounting flange) bolts. Do a preliminary tightening of these bolts to 5 N·m (44 in. lbs.) torque. This preliminary tightening insures the fuel injector is seated and centered. After tightening, relieve bolt torque, but leave both bolts threaded in place.
If required, assemble o-ring to injector fuel supply connector. Lubricate connector bore and threads. Install fuel supply connector into cylinder head by engaging locator into groove and push to engage o-ring. Install fuel supply connector nut (fitting) into cylinder head. Do a preliminary tightening of this nut to 15 N·m (11 ft. lbs.) torque.
Perform final tightening of fuel injector mounting clamp bolts to 10 N·m (89 in. lbs.) torque.
Perform final tightening of fuel connector nut to 50 N·m (37 ft. lbs.) torque.
mitm
Aug 16, 2009 09:29 PM
Firstgenfanatic
May 14, 2008 06:17 PM
mainer
Jul 17, 2007 07:13 PM
PapaSmurf
Dec 19, 2003 02:14 PM
Davidp
Feb 1, 2003 05:49 AM
