i really dont know????
Old Sep 3, 2010 | 10:21 AM
loya 3500's Avatar
My turck has been doing this for some time now and its going to make me go crazy if i dont fined the problem..
when i am driving on the road and let off the pedal and get back in to it to speed back up the truck jerks like it has slack in it some where. the u joints are good. other then that i dont know where else it would come from.
What do yall think??
Thanks
michael
Old Sep 3, 2010 | 10:40 AM
Foxborough's Avatar
You will need to fill in your signature a little more. Auto or manual tranny? I would jack up the rear and see if there is any play. I assume you have an automatic and the problem is something in the tranny. Inside there is beyond my expertise, at least I gave you a bump.
Old Sep 3, 2010 | 10:45 AM
loya 3500's Avatar
it is an auto trnny..
Thanks foxborough..
Old Sep 3, 2010 | 11:35 AM
BigIron70's Avatar
Cummins Guru
I agree, check rear diff for play in gears and Trac-Rite for excessive play. I have seen the thrust washers going out in Trac-Rite and causing excessive play in gears. If you can rotate your rear wheels more then 15-20 degrees before you take up gear backlash then you have too much play in the Trac-Rite gears. I have seen some that rotate up to 180 degrees before backlash play is taking out of gears. The Trac-Rite is serviced as an assembly. I'm assuming you have 11 1/2 AA w/Trac-rite
Old Sep 3, 2010 | 01:23 PM
loya 3500's Avatar
i dont know about the AA/trac-rite but its all stock on the rear end. i guess ill put it on the lift this weekend and see if there is any or how much play there is.. in the rear...
thank you. bigiron70
any more ideas would be good
Old Sep 3, 2010 | 02:34 PM
Hodge's Avatar
Yea, the first thing I would do is get the back tires off the ground, and see just where the play is. Thing is, most vehicles have some play, if you really try hard and throttle on/throttle off. There are a lot of moving parts, and a little wear/play here and there adds up. Some play is acceptable. The question is how much, and where from.
bigthumper
Aug 16, 2005 08:04 AM
canucktrucks
Aug 19, 2004 06:34 PM
CCCummins
Apr 23, 2004 01:23 AM
midwestdually
Nov 18, 2002 11:30 AM
