HX40 Question
Old Aug 21, 2007 | 06:50 PM
spyder3634's Avatar
HX40 Question
I am in the process of putting an hx40 on my truck and I am having one issue. The wastegate is in the way of the compressor housing and it is making it so the housing will not match up to the intercooler pipe. I have tried moving the wastegate and the housing and nothing makes it line up. Need some advice asap!
Old Aug 21, 2007 | 07:06 PM
Dodge359's Avatar
I had to modify the actuator from my hx35 to fit. I drilled an extra hole between the two twards the head and used the spacers to hold it from crushing when I tightened them. Just make sure you get the right angle as a 40 has a different arm. If you really want to change things you can grind the arm off the 40 and turn it 90* and use the one off the 35. If you want the one I have send me yours and I will trade.
Old Aug 21, 2007 | 07:07 PM
Dodge359's Avatar
I went twin with my 40 and had to use the original wastegate as I had the same problem when I indexed it for the 3b turbo.
Old Aug 22, 2007 | 08:26 AM
spyder3634's Avatar
thank you very much! I grinded off the arm and re-welded it, used the 35 actuator and everything works great! Thanks again!
Old Aug 22, 2007 | 08:41 AM
Dodge359's Avatar
Good deal. One thing I have learned from these 5.9s is there are very few plug and play upgrades.
Old Aug 22, 2007 | 09:23 AM
spyder3634's Avatar
yeah that is for sure! I appreciate the help, now only if I could get this 40 to spool as fast as the 35...haha
3500_CTD
May 22, 2008 09:49 PM
schoust
Apr 27, 2007 11:19 PM
Hawkeye
Sep 23, 2003 08:22 PM
shaft01
Nov 22, 2002 08:46 PM
