Hunting Lockup
Old Jun 27, 2007 | 03:15 PM
xxsniperx's Avatar
Hunting Lockup
Its a 96 4x4..... So its been jumping in and out of lockup... I did the brake switch, TPS sensor, and also got the noise isulator wire from BD Diesel and its still jumping in and out. I cleaned some grounds and powers but i dont know what else to do... It seems to do more often and worse on hotter days.. Sometimes it wont do it at all on a cool night. Trannys running at 140 to 160 degrees and fluid is full. Thanks
Old Jun 27, 2007 | 04:28 PM
Buckshotram's Avatar
i would check your trans temp sensor. If its bad it will make it lock and unlock
Old Jun 27, 2007 | 06:30 PM
xxsniperx's Avatar
Does anybody know where them tranny temp sensor is on a 96?
Old Jun 27, 2007 | 06:40 PM
mr T's Avatar
did u adjust the brake switch? double check and re-adjust...takes 3 seconds
if ur still having trouble I would install the lock-up switch so that u can ride home on the interstate in peace
Old Jun 27, 2007 | 06:56 PM
xxsniperx's Avatar
I tried the lockup switch but my truck falls right in the years where i need a reflash for it to work
Old Jun 27, 2007 | 06:57 PM
infidel's Avatar
I've found that many times you just have to bite the bullet and replace the TPS
Old Jun 27, 2007 | 07:31 PM
xxsniperx's Avatar
Yea man i bit the bullet and replaced the tps today and i still have the problem. New TPS didnt do anything.
Old Jun 27, 2007 | 08:37 PM
xxsniperx's Avatar
What does the tranny relay do?
Old Jun 28, 2007 | 06:26 PM
xxsniperx's Avatar
anybody have any other ideas???
Old Jun 29, 2007 | 03:19 PM
mr T's Avatar
did u install the TPS yourself? if not then obviously take it back to the guys that installed it...if u did it yourself then do a search on TPS adjustment...it is adjustable
Old Jun 29, 2007 | 04:15 PM
John Faughn's Avatar
Also check the brake sw.
The temp sensor is in the hot line going to the cooler , drivers side .
93dieselZak
Jun 16, 2011 06:10 PM
JQmile
Sep 15, 2010 10:43 PM
Cowboy_Customs
May 6, 2008 09:39 AM
pokapotato
Aug 23, 2007 09:48 PM
