huge miss
Hi all , very informative deally you've got goin on !!
I have a 01 3500 I just installed a TST pm2 box on and it has a huge miss seems only to be in 5th gear over 2500 r's I dont think its connection related because it would be more inconsistant,however the grn lite on the unit flashes off when its dyin. I checked for codes and got none,any ideas? thanx in advance
OK, have you pulled the box to see if the problem goes away? The only problem I ever had with my PM3 was the pump wire connection not being good, which set a code. I made sure that connection was OK and no problem since.
If the problem goes away when you pull the box, then reinstall and see if it comes back. If it does, than call TST about it.
Chris
Chris
bigbaddiesel
Aug 19, 2003 09:00 PM
