Hub assembly replacement tricks
Old Apr 20, 2007 | 10:58 PM
nubbs00's Avatar
Any body have any other tricks on removing the bearing assemblys from the front axel besides hamering on the bolts?
Old Apr 21, 2007 | 12:34 AM
95ram's Avatar
Some have used and extension and socket on one of the back bolts. If I rember right you put the socket with 3" extension on the bolt start the pickup and turn the wheel so the extension hits. I tried this and it didn't work for me. I had to beat the crap out of the bolts to finally get it to come loose.
Old Apr 21, 2007 | 07:35 AM
berner's Avatar
I've had luck turning the wheels, sticking a socket between the u-joint and the axle tube and getting somebody to turn the steering wheel back. Be careful that you don't damage the ABS sensor ring. Clean up all the rust and coat everything with never-sieze before putting it back together.
Old Apr 21, 2007 | 07:41 AM
dieselrob's Avatar
The socket extension using the steering as a press should work every time. I was trying to hit mine out then i got on here and found that trick out. It seemed like it fell out once i turned the wheel.
Old Apr 21, 2007 | 09:56 AM
nubbs00's Avatar
Thanks Gents, I,ll give it a try!
Old Apr 21, 2007 | 12:37 PM
infidel's Avatar
Old Apr 21, 2007 | 05:50 PM
Dr. Evil's Avatar
I tried that same trick - didnt work for me. I ended up just bending that plate in the pic where the lug nut is seated. I was replacing the rotors anyway, so a couple of 5 pound hammers got them off nicely.
Old Apr 21, 2007 | 05:54 PM
ClackClack's Avatar
Extension trick worked flawless for me. Getting the rotors off was harder than getting the hub out.
Rafter B
Jan 11, 2009 08:40 PM
Big Smoky
20
Mar 18, 2005 09:42 PM
XLR8ER
Nov 26, 2004 09:31 PM
CTD99
Sep 16, 2003 06:41 PM
rich
May 9, 2003 09:33 PM
