How to remove upper ball joint
Old Oct 2, 2009 | 02:23 PM
dieselfuelonly's Avatar
DTR question asker
Does the upper ball joint on a 1996 2WD 3500 with IFS screw out or is it pressed in? Bottom one came right out with a ball joint press and one whack from a sledge hammer but the upper one is giving me trouble. I have a ball joint press. If its press fitted, which direction should it be pressed to remove it, up or down? Thanks for any info.
Old Oct 2, 2009 | 04:50 PM
RPegram's Avatar
Press in. This one might take two whacks.
Old Oct 2, 2009 | 07:47 PM
DTR question asker
Do I need to press it down from the top? It seems like this upper one has a much bigger "cap" on it than the lower one did... no snap ring, right?
Old Oct 3, 2009 | 06:51 AM
RPegram's Avatar
The shaft of joint will press through control arm. It should go up through control arm. Should not be a snap ring. Once you get it out, take some fine sand paper and lightly clean the bore in control arm and apply a generous amount of anti-seize to both arm and joint before pressing in new joint. Put anti-seize on all threads and shafts, you will appreciate it later.
Old Oct 3, 2009 | 10:30 AM
DTR question asker
Ok, up through the control arm. That makes more sense, it sure didn't look like it'd fit through the other direction.
Thanks for the help ya'll... hopefully I can get them all out today. Then the only thing left is to get that stubborn pitman arm off .
Old Oct 3, 2009 | 05:45 PM
RPegram's Avatar
Pitman arm puller and it will come right off.
EdmontonCanada
37
Feb 4, 2016 12:02 PM
TJE
Jun 8, 2012 08:43 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
miketriton
Nov 8, 2004 08:04 PM
Jdonoghue
Jul 27, 2004 10:08 AM
