how to get codes
Old Jun 19, 2005 | 12:28 PM
plow's Avatar
how to get codes
will the key method work on my truck to retrieve codes? when i do the key method i get a 1255 code i can't find anything about this one, that's why i was wandering if this method will work on my truck. if this is right does anybody know what this code means? thanks.
Old Jun 19, 2005 | 03:59 PM
12vordie's Avatar
This method will work on your truck. The check engine light flashes the code. From what I can tell you are getting a code 12 which means that there has been a problem with the battery connection, you have had the batterys disconnected whithin the last fifty starts, and a code 55 which means completion of fault code display, which means the computer does not have any fault codes stored.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
