High RPM's no power!
High RPM's
Mainly only does it in 5th when i'm trying to get up to highway speed, also when i press on the acceleration button for the cruise it kicks it back like it's governing out. Clutch is good, already replaced the fuel filter and had the tranny serviced.
Cummins Guru
Plugged air filter will definetly give you lack of power at high rpm. Had a truck in shop last week air filter looked good but engine had no power. Put new air filter and it was like a new truck. Customer didn't believe me so he wanted to go drive truck with me. He was a happy camper afterwards. Check fuel flow also, if fuel pump vol is low will cause problems also. If you have high miles on truck fuel pickup in tank can also be plugged up. Did you get the fuel pump replaced yet with intank pump??
The Lift And Fuel Pump Were Replaced Back In 06 Because There Was A Recall On Them, They Are External Mounted On The Fuel Tank Now Instead Of Being Inside It. Check The Air Filter Yesterday And Its Only A Couple Weeks Old. Doing A Process Of Elementation Now, Had A Dianostic Done On It Today And They Couldn't Get A Reading Cause Of It Not Having A Check Engine Light On. Thinking That It Could Be The Injecters And The Fuel Line Being Clogged.
The engine revs up when you put your foot on the gas while in 5th gear but it's not transmitted to the wheels right? The cruise kicks out because the engine speeds up but not the ground speed, right? If these are true it MUST be the clutch slipping.
Moobesor
May 31, 2008 11:17 AM
jmccart
Jun 12, 2007 02:12 PM
fishin fever
Feb 22, 2004 08:32 PM
klrmark
Sep 4, 2003 09:37 PM
