help w/ abs light please
I have 98 dodge ram turbo diesel 24v m abs light and brake warning light comes on at the same time my speedometer fails I have changed the reaer axle speed sensor and transmition speed sensors several times with varinng degrees of success. I did have a pcm reflash to cancel a signal from the alternator which helped for a little while. I do believe that the problem is some how related to a signal from the alternator because because when the failiure occures the speedometer moves in relation with the rpms. I have also have observed that this problem is ambient air temparature related in the morniing when it is cooler there is no problem at all.
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
