help / suggestions please
Old May 6, 2010 | 09:08 PM
jimbirney's Avatar
I have an 01 2500. Substantial mods have been done to the truck prior to an accident. The truck has been sitting for about 3 years. I am trying to get it running now. I have cleaned the fuel tank, Changed the oil, and taken the turbo apart and cleane it.
I rebuilt the FASS pump and changed all the filters.
The truck cranks over, but does not appear to be getting fuel.
I disconnected the fuel line at the vp44 and let the pump run utill I have fuel at the vp44.
I diconnected one injector line and cranked motor, but am not getting any fuel from the injector line.
Any help would be greatly appreciated.
Thanks
Jim
Old May 6, 2010 | 10:32 PM
rebal's Avatar
pull the codes see if you have any
Old May 7, 2010 | 06:42 AM
jimbirney's Avatar
The only codes are 1492 and 1692
Thanks
Jim
Old May 7, 2010 | 08:42 AM
rebal's Avatar
check your ECM,might have a problem with it (1692 fault in ECM )
Old May 7, 2010 | 09:55 AM
iforge03's Avatar
you probably need to break open at least 2 more injector lines to get the air and get it started
Old May 8, 2010 | 01:37 PM
jimbirney's Avatar
I removed the Injector lines from #2 #4 and #5. Cranked the engine for a few minutes and am getting fuel from those 3. I reattached them and crank moteor. Does not even sound like it wants to start.
Codes are 1492 and 1693
Suggestions please????
TIA
Jim
Old May 8, 2010 | 03:47 PM
jimbirney's Avatar
update....
still no start, disconnected air tube and used ether. Truck will start on ether, as soon as ether is removed truck stops,
I disconnected the injector lines again and started truck with ether, Fuel seems to be just trickling from the injector lines.
Help / Comments please
Jim
Old May 8, 2010 | 10:21 PM
rich's Avatar
sounds like a dead vp
Old May 9, 2010 | 08:47 AM
jimbirney's Avatar
Anything on the vp I can check, Voltages, Ohm's, Etc.
I replaced the vp a month before the accident.
TIA
Jim
Old May 9, 2010 | 09:31 AM
jhenson's Avatar
I'm with rich on this one....sounds like a dead pump! With the engine running (dare I say on ETHER) you should be getting a good spray of fuel if the pump is up to snuff.
Old May 9, 2010 | 12:20 PM
jimbirney's Avatar
Does anyone know of a place that will rebuild the vp44. As I said, the pump is only a month old with about 5,000 miles on it. If it is bad, it only thing I can think of would be the diaphram from sitting.
Jim
Old May 9, 2010 | 12:25 PM
rich's Avatar
Jim
that or it has abuoild up of gunk and algae and has the internals clogged
Old May 9, 2010 | 12:37 PM
rebal's Avatar
TIA
Jim
Thanks
Jim
1692 is an ECM fault 1693 companion code have the VP tested it might be the ECM
Old May 9, 2010 | 12:39 PM
jimbirney's Avatar
Can it be cleaned or is there an additive that I can put in the filter and push through it. I haven't much experience with the VP44 other than replacing it.
Jim
Old May 10, 2010 | 12:16 AM
iforge03's Avatar
do you have a programmer? try downloading a program and see if the ecm is able to communicate. when my ecm died, that was how i figured it out
