help rear end
Old Oct 5, 2004 | 02:21 PM
darkvader's Avatar
help rear end
My son has 2001 1500 4x4 with ls diff. He had a howl that turned out to be he lost one of the keepers that retain the clutch pack. Gear shop wants $1400 to rebuild. Is this a bit much. I am to far away to help but I used to rebuild rears alot and this seems about twice what it should be. corse last one was 12 years ago(3/4 chev new bgrns r&p and new detroit locker bout 700 if I remember) m
Thanks for any input
Clark
Old Oct 5, 2004 | 02:33 PM
darkvader's Avatar
opps it is a 1999
Clark
Old Oct 5, 2004 | 08:36 PM
coiler33's Avatar
Need a little more info, are they replacing king gear and pinion gear or just shims and bearings and seals. Just did my total cost of rebuild parts $768 Canadian sorry dont know about labour but would guess no more than 4 hours. Post back with parts list and I will get back to you with cost on Dana 70 prices I paid.
Old Oct 6, 2004 | 10:15 AM
darkvader's Avatar
Apparently complete rebuild. R&P, bgrns. Turns out they are using aurburn ls carrier so I guess R&P 200, aurburn 400, brgn 80, misc oil,shims parts 100 mabey not to bad a price. Has anyone have experiance with aurburn ls
Clark
Old Oct 6, 2004 | 12:35 PM
FRANKV569's Avatar
well, if it were me , i would investigate the cost and availability of buying a complete rearend-used and rebuilt. i believe that the 1/2 ton uses the chrysler 9 3/4 rear? a buddy of mine bought a used rearend for his last year from an auto parts rebuilder and it set him back like $900. with a 6 month warranty. i did the research for him and i can tell you that several places i called wanted like $1400. for a used unit with high miles and no warranty--so , if you go that route , shop around! also, if it were me , and i planned on keeping and maybe ''working the truck'' , i would investigate the feasability of getting a complete dana 60 rear or dana 70 out of a 3/4 ton-and making it fit (moving the spring perches, u joint or driveshaft change/modification). i mean, instead of paying 14 bills to rebuild your innerds-get something good for similar scratch -possibly.
Old Oct 6, 2004 | 10:15 PM
KATOOM's Avatar
I think I understand what you are asking and if there is a need to replace the carrier or the gear set then I can understand a higher cost but $1400 does sound pretty steep. If there is only some internal parts that need to be replaced, like clutches and retainers, then there is no need to reset the carrier or pinion so the cost would be minimal. That would probably be something that could be done at home, if there is any mechanical knowledge.
2500CTD
Oct 19, 2010 07:10 PM
RichN
0
Aug 6, 2010 06:52 PM
1999blackcloud
Jan 26, 2010 08:52 AM
doorguy
Jun 8, 2007 06:19 AM
royta
Jul 13, 2004 06:54 PM
