Help Need resistor
Old Feb 2, 2007 | 08:00 PM
Dalbery's Avatar
Help Need resistor
I'm wiring up some HID headlights and I need some 3-4 ohm 100watt resistors. Does anyone know where I can find these? Or what I can use as a substitute? Car speakers worked for testing purposes, but they heat up and blow.
Thanks,
Darrell
Old Feb 2, 2007 | 08:23 PM
TIMMY22's Avatar
radio shack?
Old Feb 3, 2007 | 05:29 AM
AlpineRAM's Avatar
Do you need them as a voltage reducer? if so you can get some voltage regulator chips that will regulate the voltage down to the desired level and stabilize it there without burning off the energy like a resistor does. They do a duty cycle to charge a small capacitor to achieve the desired voltage.
HTH
AlpineRAM
Old Feb 3, 2007 | 09:15 AM
TonyB's Avatar
You should be able to source the parts from any one of these suppliers:
www.digikey.com
www.mouser.com
www.newark.com
www.alliedelec.com
Try to stay with aluminum heastink type & mout them to the chassis for better heat dissipation.
HTH
Tony
Old Feb 3, 2007 | 01:16 PM
Dalbery's Avatar
Tony B-Thanks.All of those suppliers have them. Please forgive my inexperience, but do I wire the resistors in line on the positive side. Or do they need to go from pos to neg to show resistance on the circuit?
Alpine ram- I need these to show resistance to fool the computer into thinking the lightbulb is still there. If you don't show enough resistence or load the computer drops the voltage to the headlight circuit to like 3.2vdc which isn't enough to fire the HID's.
Thanks to all
Darrell
Old Feb 4, 2007 | 12:17 PM
XLR8R's Avatar
That's how I'd do it.
FP3
Aug 13, 2009 09:20 PM
dieselfan
Dec 16, 2008 03:25 PM
99 cummins
Aug 3, 2005 09:25 PM
peanut
Apr 18, 2004 05:19 PM
LTL JON
Apr 9, 2004 07:33 AM
