Help on Jacobs Exhaust Brake
Old May 30, 2003 | 10:09 PM
DawgII's Avatar
From: Land of Oil Wells, Sooners, and No-blinker using fools
OK - I have my &quot;it's 100 outside (at 9pm) and boy can I use a beer&quot; Red Sox hat on. I'm missing something very obvious!<br><br>1. I mounted the selonoid bracket - only 2 of the well caps seem to have expanded - the bracket is pretty loose -am I holding my tongue wrong or what?<br><br>2. The more important question - how do I locate the PCM or ECM 50 pin connector? The darned instructions say I don't need pull the fuel filter assembly out of the way. All I see is a connector with a &quot;void&quot; sticker on it. Is that it?<br><br>Sigh!
Old May 30, 2003 | 10:17 PM
emjay's Avatar
Re:Help on Jacobs Exhaust Brake
The ECM 50-pin connector is virtually invisible until you remove the fuel filer/water separator. You don't have to remove the fuel lines, just the two bracket screws that hold it to the head. There is a screw that holds the connector to the ECM. The cavities are numbered, and they're arent that many empty cavities. The rubber plug was a bit*h to take out -- mine came out in pieces. once you snap the pin in and re-connect the ECM, you should be good to go.
Old May 30, 2003 | 10:31 PM
DawgII's Avatar
OK - I'll attack it tomorrow. All that's left to do is: Push the current pin 20 out and insert the new one, mount the interior switch and ops check. Those well nuts really bother me though - 2 are perfect, the other two never expanded...any ideas? If not, I'll RTV the loose plugs in and look for a couple nut plates. If it weren't for the heat I could think it through.
Old May 31, 2003 | 11:25 AM
emjay's Avatar
Just to clarify -- there should not be a pin in cavity 20, just a rubber plug. If you're trying to remove a pin/wire, you probably are working on the wrong cavity!<br><br>Also, I have a PacBrake, so I have no idea what you're talking about with regard to well caps expanding and holding your tongue wrong ???
Old May 31, 2003 | 06:55 PM
DawgII's Avatar
Re: Clarifying the Clarification
Yer right, of course. I mis-typed. The well nuts are combination bushing/nut plates that fit in the plenum right next to the air cleaner box.
Old Jun 1, 2003 | 08:10 AM
DawgII's Avatar
;D ;D<br>It's Installed!!<br><br> Actually the E-brake and new (egt/boost) are installed.<br><br>Final E-brake question: I hear a hissing noise whenever it engages. Seems to becoming from the brake or aft. Is this normal?<br><br><br><br>
Old Jun 1, 2003 | 04:05 PM
emjay's Avatar
Yes, hissing sound is normal.
Old Jun 1, 2003 | 11:03 PM
Ramflasher's Avatar
Yep! I agree...the hissing sound is normal. <br>
Old Jun 2, 2003 | 03:55 AM
Dieseldude4x4's Avatar
The hissing noise coming from the rear of the truck is the sound of the exhaust that is normally semi-free flowing out through the exhaust system now being stuffed through a tiny little opening all around the butterfly valve that you've just bolted into the sustem. Remember the old stuff a potato in the tailpipe thing, this is the same thing only not quite as much fun.
Shilohman
22
Nov 19, 2009 05:13 PM
iflych52
25
Oct 10, 2006 09:25 PM
Apr 2, 2003 12:14 AM
Mar 26, 2003 07:48 AM
