Help I'm In Trouble!!!!
Old Mar 6, 2006 | 12:58 PM
piperca's Avatar
I am in the midst of replacing my VP. I was pulling the gear and the gear came off the VP shaft ok, but the VP is still lodged in there. How do I get it out???? Please, someone have the answer!
Old Mar 6, 2006 | 01:15 PM
piperca's Avatar
Ok, I got it out, but now I see the support bracket is broken. Does anyone know what's involved in fixing this? It looks like a load of work!
It looks like I've got to remove the power steering pump. Does anyone know the procedure?
Old Mar 6, 2006 | 02:24 PM
ratsun's Avatar
I dont really know that this helps you but.. Mine was broken too and I just assembled it with out it
Old Mar 6, 2006 | 03:37 PM
Copenhagenjunkie's Avatar
Yes it has to be removed according to alldata.
I can fax you the procedure from alldata.
Old Mar 6, 2006 | 03:45 PM
6WHEELER's Avatar
well, you got to get the new bracket from cummins( pt # 3938707), I got the bracket number off one of the post on here, it's two pieces in the kit. you have to remove the power steering pump, to get the bracket off the block, and to get it back on then replace the steering pump. Install the 2nd bracket on the pump and install that, then bolt the two together there is and set on instruction list on here that I used to do mine. You must have this bracket to support the back of the pump or the vibration will shorten the life of the pump.
Old Mar 6, 2006 | 03:52 PM
Geico266's Avatar
Can you take it off the truck and weld it?
Old Mar 6, 2006 | 05:13 PM
piperca's Avatar
I just got back from Cummins with the new part. It's much sturdier than the original. I guess they were having problems with the 98.5-99 trucks, so the changed the part. As far as the power steering unit is concerned; is it going to make a huge mess when I remove it? Anybody got any tips?
Old Mar 6, 2006 | 06:29 PM
piperca's Avatar
I seperated the vacuum pump, where the o-ring is (it was leaking anyway), so I'm going to replace that while I'm at it. Got the new bracket on, but now I've got to go to Dodge to get the o-ring ... or is this something I can get at any autoparts store?
Old Mar 6, 2006 | 06:36 PM
AggieJustin's Avatar
Dodge doesn't sell that part seperate, they always say you have to replace the entire pump. But from posts I've see on here, you can get the seal at any good industrial supply house. It's a double lipped Viton seal, size 28x38x7.
Info in this thread: Vacuum pump seal
EDIT: Had the wrong seal size
Old Mar 6, 2006 | 06:57 PM
piperca's Avatar
I checked out the old seal and it seems fine. What do you think?
Now I'm having problems with the new bracket. I can't get the thing to line up! What gives??? Has anyone done this bracket before?
Old Mar 6, 2006 | 07:04 PM
FIREDUDE's Avatar
you can get a vaccum pump reseal kit from dodge, i got one for my 91, they just started making the for the 01 and up models but will work on older models as well, if you would like i can get the part number for you
Old Mar 6, 2006 | 07:14 PM
Dr. Evil's Avatar
Correct, DC must have seen that people werent buying Vacume pumps so they brought out a repair kit.
Old Mar 6, 2006 | 07:44 PM
piperca's Avatar
Ok, here's where I'm at: Got the pump in, but it's about an 1/8" away from seating. Can I just draw it in with the nut on the shaft?
Old Mar 6, 2006 | 09:34 PM
duner's Avatar
i'm waiting to read the official report on this question because my gut response would be no.
Old Mar 6, 2006 | 09:42 PM
If you're talking about the vacuum pump, I think I read here that it slips on down till that last 1/8". Then you just have to work it around till it finally slips the rest of the way down. I wouldn't draw it down using the nut.
