(help) hesitation around 55 to 60 after installing injector pump
Old Dec 3, 2007 | 05:33 PM
blackdually6's Avatar
Question (help) hesitation around 55 to 60 after installing injector pump
1999 dodge 3500 dually 120 horse edge comp box 80 horse injectors dunrite triple lock with vavle body just installed injector pump and fuel pressure gauge if u tromp it taking off from a stop fuel pressure drops to 0 for a few seconds but not every time also have a flutter /hestitation around 55 to 65 every now and then when it dose that and you give gas it shifts down and takes off but it just dont seem to have the power it did have on take off the fuel pressure stays around ten driving down road normal when it flutters or hestitates the gauge dose not drop or or flutter neither dose the boost gauge i also put new fuel filter in it what else could i do to fix problem?
Old Dec 3, 2007 | 06:17 PM
TLDC's Avatar
My buddy replaced my VP44 3 times (second one was defective), she was still acting up so then he put in a new Vulcan draw straw, new fuel lines, gauges and FASS fuel pump. He also changed the fuel filter about 3 times during all this. She is up and running very good now!!!
Old Dec 3, 2007 | 06:29 PM
was your acting like mine do u think if i put fass system on it it would cure the problem
Old Dec 3, 2007 | 06:45 PM
TLDC's Avatar
Is your fuel pump in the engine compartment? Mine was, and from what I was told the pump works alot better when it's mid-line on the frame. The fuel pumps that are located in the fuel tank I've heard aren't good either.
Old Dec 3, 2007 | 06:53 PM
yes mine is in the enginge compartment i put a holy blue pusher pump on the frame ive burnt two of them up now im just running stock transfer pump
Old Dec 3, 2007 | 07:00 PM
TLDC's Avatar
If it was me, yes I would put the FASS pump on again. I just put the "normal" FASS pump on, I don't race her. I went to genosgarage.com they have all three FASS pumps I believe.
Old Dec 3, 2007 | 07:04 PM
ok thank for help
abc4yew
Mar 22, 2015 03:52 PM
leper
Oct 26, 2014 10:51 PM
w63
Jul 25, 2010 09:23 PM
SOhappy
Sep 15, 2009 08:34 AM
dodgediesel4x4
Dec 1, 2004 03:45 PM
