HELP!!! Goes into drive wont move.
Old Apr 6, 2007 | 11:34 PM
hkmp5sd's Avatar
Unhappy HELP!!! Goes into drive wont move.
I was driving to work the other day when I got on it to pass someone i heard a loud clunk and truck stayed running but lost all drivetrain power. I towed it home and checked the u-joints, drive shaft all looked good. I lifted rear end off
of the ground and was able to spin both tires and the drive shaft moved with the truck in park, when i put it in 4H i am unable to spin the rear tires. I have tried putting it in all gears and in 4 wheel drive, checked fluid level and still no go. I think the transmmison is a 48re.
Thanks
Larry
Old Apr 7, 2007 | 06:10 AM
bill50cal's Avatar
broken transmission output shaft or transfer case input problem. pull transfer case and try to turn trans output shaft in park. if it turns, time to pull trans
bill
Old Apr 16, 2007 | 06:12 PM
hkmp5sd's Avatar
Thanks Bill- I pulled the transfer case and it is the output shaft. I took the Overdrive unit to the shop today for a new output shaft.
Thanks Again
Larry
L.J.B.
Jun 27, 2014 10:21 AM
thenrie
Sep 25, 2011 04:47 PM
safecracker909
Nov 28, 2010 10:22 AM
vp_mopar
Nov 21, 2008 07:22 AM
converteddzlr
Jul 29, 2005 01:35 PM
