Help With Front Seal
Old Mar 24, 2004 | 08:29 PM
Stamey's Avatar
I need help with this front seal. When I pulled the timing cover it came off in 2 pieces. There is a seal in the cover still, but this other seal (second seal?) came off and fell on the floor. I wasn't watching for it and did not see how it was installed. I am ready to put it back on now and am not sure how this "second" seal goes on.
See pics.
Thanks,
Chris
Old Mar 24, 2004 | 08:31 PM
Stamey's Avatar
Another pic of it, flipped over.
Chris
Old Mar 24, 2004 | 08:52 PM
MnTom's Avatar
I would think that the "second" seal is something that somebody added. If you want to put it back in just put the spring side to the inside.
Tom
Old Mar 24, 2004 | 10:07 PM
Stamey's Avatar
OK, I installed it by putting it on the crankshaft after installing the timing cover, the same direction as it is laying in the first picture, lip side in/down.
I'll find out tomorrow if it leaks or not. (fingers crossed smiley here)
Chris
Old Mar 25, 2004 | 09:15 AM
Redleg's Avatar
That is a dust seal. I haven't done the timing cover, but it looks exactly like the set-up used on the 4wd hubs. When you get a seal kit with the bearings, they usually come with that. As long as it is not damaged or set-up or deformed, you can re-use it. I'm pretty sure you re-installed it correctly. If it was a little distorted, I wouldn't swet it too much, it sound like you were just successful on a 50-50 bet.
sootnsmoke
Jul 17, 2011 06:31 AM
92smokin blacky
Mar 6, 2011 01:09 AM
92smokin blacky
Jan 4, 2011 12:43 AM
RTillery
Feb 7, 2009 08:46 AM
dieseljerk
Jul 8, 2004 07:23 AM
