Help charging problem
Old Jul 17, 2011 | 12:14 AM
ardpms's Avatar
I need help my 97 cummins 5 speed is not charging the batterys took alt had it tested and it is fine they said, it reads 10v or less on batts when running the gen light is on what can i do to fix problem i checked all battery connections and they are good ,any help would be a big help to me thanks
Old Jul 17, 2011 | 09:39 AM
clops79's Avatar
check crankshaft sensor, do any of the other gauges act up
Old Jul 17, 2011 | 01:43 PM
patdaly's Avatar
Tach working?
Old Jul 17, 2011 | 02:37 PM
ET RAM's Avatar
Have your batteries load tested too. You can do a couple of voltage tests. With engine off, test the battery voltage. Then on large terminal on back of alternator, test for voltage. You should read the same battery voltage. If you read battery voltage then then alternator feed cable to battery is good. If you do not read battery voltage, there is a break in the system somewhere. Check the fuse.
Now start engine and check for voltage on large terminal on back of alternator. It should read 13-15volts. If you are getting that reading the alternator is charging. If you do not get that reading, the alternator is not charging in the vehicle.
Old Jul 18, 2011 | 11:15 AM
ardpms's Avatar
charging
all other gages work will check battery voltage on alt tonite but i am begining to think the computer is not telling it to charge
Old Jul 18, 2011 | 10:41 PM
patdaly's Avatar
Did you check the big fuse as well?
Before you suspect the PCM, make sure you wring out all the wiring and connectors, it would be very rare for it to be the PCM.
Old Jul 23, 2011 | 12:17 PM
ardpms's Avatar
charging
thanks all it was the pcm and i adapted a gm 1 wire alt to my truck thanks for all the info
Diesel-Dan
20
Sep 22, 2019 09:34 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
GoinAndABlowin
Sep 9, 2006 02:52 PM
RAM2940
Jul 16, 2005 07:22 PM
