help big problem
Old Apr 24, 2007 | 10:34 PM
lee5281's Avatar
Angry help big problem start and die moving or not
i have a 2003 3500 5.9 turbo when i come to a stop and the rpm drops below 1000 it will die but immediatley restart and run great until it drops below 1000 rpm again also i start it while in park and it will die in a few seconds or more and restart with no problem and die again shortly there after i have a new injector pump, trany sensors, fuel lift pump in tank, and a new crank sensor i was informed it could be an ads relay or mabye i need to have the reflash done at the dealer. i have spent 2200.00 in repairs that did not solve the problem. please can anybody help
Old Apr 25, 2007 | 11:11 AM
03 ant a hemi's Avatar
Your saying that you replaced all those components to try and solve the issue of your truck stalling?
Are you getting any codes, is the check engine lite comming on?
I would look at the throttle position sensor TPS (APS), next I would go to the dealership and have them check the ECM.
This should tell you if your having an electricle issue some where. Loose wire or what not.
My best best bet would be either a bad TPS or a bad ECM.
good luck
Old Apr 26, 2007 | 03:06 PM
lee5281's Avatar
no i'm not geeting any codes or a check engine light i was informed that it could be the asd relay which i changed or that the computor needed to be flashed i think i might try the throttle position sensor but i figured that if it was bad or not working correctly that it would throw a code or make the check engine light come on.
Old Apr 26, 2007 | 03:12 PM
Crimedog's Avatar
I think at this stage in the game the best option might be to bring it into a dealership and see if they can diagnose it. The diagnostic fee would be much cheaper than throwing parts at it IMO. Good Luck though, and keep us posted on what you find out!
Old Apr 26, 2007 | 03:44 PM
lee5281's Avatar
i've had it in the dealer 3 times for this very problem and it still does the same thing but i'm hearing bad repor about that perticular dealers service and repair facility so i will try the tps switch and if that does not work i will choose another dealer to take it to but i will keep all informed on the outcome.
JSCumms2000
20
May 6, 2007 02:14 PM
Mexstan
Sep 16, 2006 05:29 PM
boiler-rat
Jan 16, 2006 03:11 PM
Dieseldude4x4
Oct 17, 2004 11:07 PM
Shaders 24v
Aug 11, 2003 10:18 AM
