Help
Old Apr 4, 2006 | 10:23 AM
JJL's Avatar
JJL
Help
Just replaced the transfer pump ( new relocation kit in the tank) on a 02 2500, need to know what the the PSI should be under load. Can't get the info from the dealer.
More info ...... the old pump was 11 psi @ idle and 4 psi @ WOT. I know the specs for the pump that got replaced should not drop below 10psi WOT according to Central Motive Power. The new pump in the tank is reading 8 psi @ idle and only 2 psi @ WOT. At this psi it seems like the injection pump will fail?
Thanks
John
Old Apr 4, 2006 | 10:39 AM
GreyTD's Avatar
from what I have read 7-9psi at idle and as low as 0psi at WOT.
P.J's Avatar
P.J
12+ would be good. Depends on what other mods you have.
I'm stock, 15 @ idle, 13-13.5 cruise 12-12.5 WOT.
ON EDIT (sorry, didn't catch the in the tank part)
9 is about max I think, 5 or so WOT is good.
Old Apr 4, 2006 | 12:01 PM
rich's Avatar
03 and up is 7 to 9 at idle 02 and down 12 to 15 at idle and depending on mods down to 6 w o t
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
